Greetings. I have recently upgraded my XT-4's firmware. I have made sure that I have the camera set to Still, not Movies. The shooting is S, not continuous, HDR or anything else. Everything is on Auto. I have the USB Auto Tethering Option enabled. I tried connecting with USB-C cable as well as USB-C to USB. I pretty much did everything in the manual. X Webcam 2 is still not launching when I connect the camera. What should I do? The reason I need this is because I want to add my Fujifilm XT-4 in Unreal Engine so I can do virtual production using a green screen. I was thinking that converting this to a webcam will make Unreal see it. Anyone tried this before? Thank you very much.
