Hello everyone!
I've just joined as I've just bought an X-T4!
I'm looking for a 'half-case' to protect the body - has anyone got any suggestions, please?  Preferably, I'm looking for a real (NOT synthetic!) leather case.
Many thanks!
Kind regards,
Julian
