Hello,
I am currently experiencing a problem with my X-T3.
When I use the mechanical shutter with high shutter speeds (1/5000s - 1/8000s), the image shows a darkening on the top part. This does not occur at shutter speeds below 1/1000s.
I don't have this problem when using the electronic shutter.
My tests below
https://duncanphotographies.prodibi.com/a/exrdx4rq7g2zlov
( Fujifilm X-T3 - 1/8000s - f2 - ISO 160)
image 1 -> mechanical shutter
image 2 -> electronic shutter
https://duncanphotographies.prodibi.com/a/rd4gde8o40271lz
https://duncanphotographies.prodibi.com/a/kjm5j80oxjmvvzz
( Fujifilm X-T3 - 1/640s - f2 - ISO 160)
Thank you for your help
Edited by DuncanLPP
