Hello!
A few weeks ago I upgraded my Fujifilm XH1 firmware to version v2.12, now I encounter some problems while shooting wildlife on AF-C mode. Normally when shooting a subject you will see the focus marks focusing while shooting and see the subject on your screen. Now with this version, or maybe some version earlier this is broken and I only see the focusing mark with a black background while shooting.
This is of course very enjoying and is not how shooting on AF-C should work, with S or M mode I don't encounter this black screen when focusing.
I'm interested to hear if more people encounter this problem.
Thanks!
Tice
