Hi guys,
I am not sure if I changed some setting or what happened, but all of a sudden I can't move the focus point (or adjust its size) using the joystick anymore. I've gone through the manual, tried to change the settings, searched the internet, and can't find a solution for the problem. Has anyone ever encountered this? Any tips are more than welcome.
Thanks!
  • 9 months later...
