Hello,
I’ve recently purchased an xt4 and am slowly getting used to the various menus and settings. One thing I can’t seem to find anywhere however, is an afl (auto focus lock) option when shooting video...?
If anyone has an idea how to achieve this i’d be very grateful!
Thanks,
GK
