Hi all,
I very much enjoy my XE4. But one issue bothers me.
I pull out the live screen to horizontal for waist level shooting. In this mode when I move the camera close to the body the live view image gets inverted ie upside down from what I was seeing normally .
There must be someway to turn this off but I cant seem to figure out. Autorotate and Autorotate PB is off .
Irritating while shooting. Please help
Thanks and Regards
Raj
  • 2 years later...
