Some context, I've been using my xt-3 to stream with an elgato camlink 4k. The image would however lag whenever I tried to use it. Once I enabled boost mode everything was smooth and working properly. The issue is that randomly the screen will flash the icons (have them turned off) and then the screen will lag again until I press a button, any button and it will return to normal. I have it plugged into to an outlet, the power settings are keeping it to never sleep and boost is still enabled when I double check it. Anyone know why it might be acting this way? I've been trying to search for a solution to no avail.
