I'm hesitating between those two gimbals from Dji. For now my set up is x-t4 + 16-55 2.8 fujinon but I will get some other equipment in the future as mic, maybe longer lens, cage etc. Today I tested rsc2 with my camera and it was quite fine but I think it was on the edge of limit. So maybe rs2 will be better choice. What do you think? Does anyone using this stabilizer with similar set up?
