Probably an old question but as a new proud owner of a x100V I was wondering if it possible to prevent the EVF screen from popping up during the viewing of images on the LCD screen (play button). I set up my viewfinder in OVF mode only with eye sensor and auto-display is off. Maybe I am worried too much but I think one of the most delicate parts of the camera is the EVF/OVF construction and I don’t want the EVF pop up all the time for nothing in my opinion. Thanks for your reactions!
