Hi Guys,
Any luck with this software using an X100F?
If so please share the procedures.
I'm using windows 10/ direct cable to the computer (no hubs in beetween).
The green led in the back of the camera just blinks after I switched it on with the cable pluged in to the PC.
Thanks in advance,
