I have the following problem with my x100V. When I set the exposure composition dial button to "C" I can use the front command dial to change my exposure. That works perfectly and much faster.
But sometimes the camera automatically changes the exposure to the maximum (+5) and I can no longer control anything. I have to turn the camera on and off a few times and then everything works again.
Carolus / The Netherlands
