I purchased the fujifilm leather case for my x100v and just leave the bottom portion off. I find that the top portion fits my adapter/filter and protects the screen. A possible option unless you only want a lens cap. Did you end up finding something that works?
    • The backslashes you are referring are just symbols denoting path.  Once you import into these LUTS into Davinci Resolve those backslashes are removed by default and you only see is the true file name which has no backslashes.  Convince yourself of this by opening the LUT folder from the Davinci Resolve Project Settings.  Do you see any backslashes in those LUT names? Of course not.  The only name you see is the one that has the underscores and the periods. These LUTS work as designed without having to change any path names.  However, they need to be set up properly through CSTs and by what is supported in Davinci Resolve.  Hence, the FLog2C LUTS cannot be used because Davinci Resolve does not support Fuji Gamut color space and the FLog2C gamut. Alternatively, Davinci Resolve does support Flog2 because the color space for FLog2 is Rec 2020 and there is an FLog2 gamut. If all you are doing is changing the path names then most likely you are not getting the correct results.
