Hi. I recently bought a Fujifilm Xa7 from eBay and noticed that if I tilt the inbuilt flash, the camera fails to detect the flash and hence does not fire. However on my Xa5 the tilting works perfectly. Also the flash socket design seems different on both cameras. I am not sure if it how the camera is designed or a fault with my copy.
Hence I am wondering if anyone with a Xa7 test and confirm it it works?
Thanks
