With the new 4.0 firmware, I found that I have to press the shutter button halfway down, before the eye-AF works.
Before the upgrade, I could just snap away, and eye AF always worked. As I mostly work with children, I do not have the time to pre-focus every shot, so for me it is worse than before.
Is there a setting I can change to rectify this?
Thx
Edited by Sarel
