Hi everyone. I am new to Fuji cameras. I love the camera so far but I noticed some weird behavior. On my 16-55 f/2.8, at any zoom range the focus by wire seems to be working properly. In manual focus mode the AF-ON works to autofocus and a touch of the focus ring the focus point moves as expected.  On my 23mm f/2 however, I cannot get the lens to manual focus. I have changed every setting I can access, updated firmware, and still nothing. The focus ring is non-functional. Anyone else have this problem? If so have you found a solution? Thanks for any help in advance.
