Any thoughts on current T3/T30 pricing these days?  eBay resales are going for on average $700 on lightly used T30's but I'm not sure it's low enough from $799 + tax new to be sufficient to pull the trigger on a used one.  Maybe sub $600 resale soon with the introduction of the new X-S10?
