When using af, if you zoom in and use it, the camera suddenly stops working. This phrase pops up. 'Check the battery'. However, I have four batteries, but the same phenomenon occurs even if I try to use them while changing. I think it may be a problem with lens production, but have other people ever experienced this??? I live in Paraguay, so I don't have a Fujifilm AS center. I'm looking for a solution.
