Hi guys!
I have a brand new x-t4 with latest firmware (1.10). For some reason, the interval shooting is disabled. I am in the still, single mode. Shutter speed is not in the bulb mode. Photometry is set to "point". Could you please give me a clue of why is the interval shooting disabled? Thank you!
