Hi All
I am hoping to get some help from you guys with two issues that I have with batteries and the XT3/battery pack. I have the latest firmware installed.
First issue is that the camera doesn't switch to a new battery once the left battery is exhausted instead it just turns off!
Second issue is when I plug in one of those super expensive PD battery banks i dont see the plug icon
Any ideas?
Many thanks
Dave
