Hi My X-t4 always crash. currently I found 2 kinds:
1. turn on and crash, then I have to remove the battery to turn on again.
2. almost every-time I use interval timer shooting, around 20 shots then I crash. need to remove the battery.
do you guys has the same problem? should I wait for the update or send it back to fujifilm?
Thanks.
