Hi All,
My issue with the X-T4 is that the camera while in movie mode does not switch from AF-C to AF-S but stays in AF-C. I called support they walked me through resetting the camera and it appeared to fix it but then boom it went back to doing it. Additionally, today the camera switched from F-Log to STD by itself. Anyone with the same issue?
Edited by Rocky
