Can someone help me with some points?
Here's the setup:
- X-T100
- Micro HDMI cable
- a china brand capture card
works enough but there are some queries:
1. XT100 is considered one of the cameras that has "clean hdmi", but once i plugged in the camera, i have to take off all display so it could work as webcam, unlike the tutorial in YT, camera has display settings on while output has none.
2. focus box/eye focus appears even display is off, what my loophole is that i stick to manual focus.
are there any settings needed so i can use AF?
i'm using the camera in livestreaming desktop games on OBS and will be used in online learning for school.
Thanks!
  • 4 months later...
X-T100 is not designed for 100% Clean HDMI out.
There are 3 ways to achieve it: 1.Video Recoding Mode  - 2.HDMI 4K 15fps - 3.Display Capture Mode
1. Press record and have a 30 minute time frame.
(This will give you Full 1080p video OUT limited to 30minutes)
2. Setting the 4K Record to HDMI instead of SD Card.
(This will give you a 4K output but only a max of 15 frames per second)
3. Remove all settings like face detection and touch from the display
(This will produce a Cropped, Blurry and Low Resolution OUT.)
Remove Display info by pressing [DISP BACK]
Remove Side buttons by disabling Touch:
  • [Menu OK]
  • Setting 2 (blue spanner)
  • Touch screen setting
  • TouchScreen Setting = OFF
Remove Face Detection [Green Box around face]
  • [Menu OK]
  • Camera 1 (red camera icon)
  • AF/MF Setting
  • Face/Eye Detection Setting = OFF
SEE THE DIFFERENCE BETWEEN "Video Recording" and "Display Capture" METHODS HERE:
Edited by Ned_Sayer
There are 2 ways to achieve it: 1.Video Recoding Mode vs 2.Display Capture Mode
(This will give you Full 1080p video!)
2. Remove all settings like face detection and touch from the display
(This will a cropped Low Resolution out.)
  • [Menu OK]
  • [Menu OK]
  • AF/MF Setting
SEE THE DIFFERENCE BETWEEN TWO METHODS HERE:
Fujifilm sent me this in response to the same question:
"The FUJIFILM X-T100 supports "Clean" HDMI output only when video recording is started.
If you do not start video recording, the camera reduces the resolution of the display and fades in the info elements.
the info elements."
For me, 4k runs okay with a China capture card.
please help me i have fujifilm XT-100, i wanna use it as webcam, i've already purchase video capture card, but once i plugged the cable, nothing happened wether in my laptop screen nor my camera display.
pleasee help, or maybe someone cand send me a tutorial video to set the camera
On 12/30/2020 at 12:10 PM, naufalnrrhm said:
"When I plugged the cable, nothing happens on my laptop screen nor on my camera display."
Please Note that the X-T100 is a very bad camera if you want to use it for streaming as a video capture device.
It does NOT have Clean HDMI out... UNLESS you press the RECORD button, which requires an SD card and is limited to 30min per session...  Or you can chose to output 4K to HDMI, bypassing the SD card and the record limit, but that will only be at 15 frames per second. This defeats the point of Clean HDMI out, as the only way you can get it, is if the camera is recording.
That being said, the camera outputs an HDMI source always when a cable is connected, so I don't think it is any settings in the camera, most probably it is your Capture card or the way you set it up on your pc, or your cable...
Try this:
  1. Press: MENU/OK Button
  2. Go to Camera 5 menu
  3. Select Movie Set-Up
  4. Set the following:
    • MOVIE MODE = 1080 (any frame rate or just set 59.94)
    • HDMI OUTPUT INFO DISPLAY = OFF
    • 4K MOVIE OUTPUT = HDMI (if Movie mode is set to HDMI)
    • HDMI REC CONTROL = ON (You probably won't need this, but just in case)
if that does not help, here are some Questions:
  1. What Capture Card are you using
  2. What video capture software are you using, OBS or something else.
  3. what OS are you on? Mac/Windows
  4. Which settings did you use to set up your capture card in OBS / other software
  5. If you plug in other source like a Game Console or TVBox in your capture card, do you get a reading
13 hours ago, Jeronimo Arias said:
I'm not able to set the USB mode in auto
What do you mean "USB Mode Auto" I am not aware of such a setting.
Are you using a USB cable or a Capture Card, if so what capture card?
...and what settings have you set here:
  1. MENU
  2. Camera Settings 5
  3. Movie Set-Up
