XT3 owner here - wondering if anyone has managed to use any of the Smallrig hdmi clamps successfully on the 2228 Smallrig XT3 cage (non-battery grip cage).
There are a few about for older x-series cages, but nothing I can find that is definitely compatible with the 2228 Smallrig XT3 cage .
Any success stories? Thanks in advance.
  • 8 months later...
