Hi everyone,
So out of the blue (unless I did something without realizing) , the view mode setting I use 'Eye Sensor + LCD Image Display' suddenly shows the LCD display before and after it displays the image. The live view of what you're supposed to ONLY see in the Eye Sensor. It used to simply display the image you took for the duration of your choice and go black and only show display in the Eye Sensor just how it's titled. I'm obviously concerned about this because of battery life.
Did I hit something? Is this a bug? It certainly wasn't an update. As I did that months ago and this only starting occurring yesterday. This is crazy!
Can someone help me out?
Thank in advance
