Hello! I recently acquired a used x100f. I love it, except occasionally it will reset the focus peaking options I have selected. I choose focus peaking high red, it works for a while, then randomly when I go to look through the viewfinder, it will be set back to the standard mode. What’s is happening? Is this normal?
