Hi everyone,
Quick question.
I just received my XT3. When I take a picture, the green back light starts to blink costantly. When it does it, I can change everything exept the front dial, which I'm using it to control the ISO.
I tried to change the sd card with a very fast one and it does the same.
Does anybody knows why?
Thank you
