I was reviewing/editing some interview footage I recently shot with the X-T3. In Final Cut Pro X and in the exported .mov file, I'm seeing some ripples or glitches in the video. I've only had the camera for two months, but I've never seen this before. See attached footage. Any ideas or suggestions?
