Fujifilm X100V vs XF23mmF2 and XF23mmF1.4 :: X100V, A Missed Opportunity :: Why X100V is better than iPhone :: More First Looks
BHphoto video – Introducing the X100V As you probably know by now (if not, do your homework and check back the X100V live blogging ;) ), the Fujifilm X100V has a new XF23mm f/2 lens, that definitely delivers a significant…
The post Fujifilm X100V vs XF23mmF2 and XF23mmF1.4 :: X100V, A Missed Opportunity :: Why X100V is better than iPhone :: More First Looks appeared first on Fuji Rumors.
Full Article on Fuji Rumors
