Hey, I've finally bought an X100V second-hand and have watched countless videos explaining the Ins and Outs (it is my first Fujifilm camera).
However, I have no control over the individual exposure components as the shutter dial appears to be locked on Auto. I know how to lock and unlock the other dials and have checked countless times that not a single button or dial is locked in the menu. What am I missing?
I cannot stress enough how it is set to 'unlock' and even if you scroll the list of selected, no box is checked.
Grateful for any advice and tips. Thank you in advance!
Hi there, I'm suggesting the obvious here but are you referring to the OUTER knurled dial which should just click/rotate or the inner dial which is the ISO. To change the ISO from Auto you need to lift up the dial to rotate it. If the outer dial does not rotate/click then there is a fault with the camera.
    • Friends,    Happy New Year!   Two simple and perhaps rather silly questions: 1.) I cannot, for the life of me, change the rear command dial setting to control exposure compensation under particular conditions: my goal is lock the exposure compensation dial on the top and use the rear command dial to control exposure compensation. In the COMMAND DIAL SETTING MENU, I have the exposure compensation setting assigned, but ... no dice! 2.) And then, it is possible to have the exposure compensation "reset" when turning the X-T5 On/Off? If I have a value of -3 exposure compensation, for example, the camera "remembers" the value, and I have to re-zero the exposure compensation. Any help towards answering these two questions would be so greatly appreciated. Thank you friends and happy shooting! -M
    • Hello everybody, This is my first post and I take this opportunity to wish all members of this forum an excellent 2026. I’m new here and although I have been photographing for many years I’m new to Fuji cameras. I very recently acquired my first Fuji camera. A X-T30iii and I need some help. I have a recipe saved on one of “C” slots in my new Fuji X-T30iii, based on Acros. Image is set to F+Raw. Natural Live View is set to OFF, but I still see the colored image on the display, and it remains colored after taking the picture. Which camera setting, if that's the problem, might be causing overriding to my film recipe? The same thing is happening with recipes based on Classic Chrome. If I move the film simulation dial, I notice there is a shift in colors. As far as I know, when using a recipe on a Fujifilm X series camera, you do not need to rotate the physical camera dial to a corresponding "film" or "film simulation" because the recipe you are using is applied and it overrides the standard profile. Am I wrong? Can someone help ion this one? Thank you in advance. Pedro
    • A Blue Grosbeak, I think. XT-5 150-600, 378mm.  Cape Henlopen State Park Delaware.
    • X-T5 150-600 at 150mm.  Cape Henlopen State Park in Delaware.
    • Picked some late season peppers and placed them on a carnival glass bowl.
