X-Pro3 screen weather proofing
By jakabasej8 · Posted
By Neil Rosenberg · Posted
By Tschortschli · Posted
In reply to the original question, it all depends on what you mean by infrared. If you mean "see thermal information", then I agree with the comments here. However, if you mean near-infrared, the X-T4, or basically any digital camera can be modified to "see" it. Check out Lifepixel.com and Kolarivision.com for more info. As regards lenses, I'm not exaggerating when I say that I have searched with great vigor (and at great expense) for a way to capture IR images with a Fujifilm camera for which I didn't have to use major amounts of sharpening to bring out the best. Zooms, primes, Fuji, Tamron, Viltrox, Sigma, Zeiss ... probably 20 lenses all told. Plus multiple IR converted Fuji cameras, X-T1, X-T3, X-T5. I even tried different ways of filtering IR, such as using the Kolari clip-ins and lens-mounted front filters. I was ready to give up until I almost accidentally tried one of the cheapest lenses out there -- the little TTArtisan 27mm F2.8. No hotspots that I could see, and best of all ABSOLUTELY SUPERB SHARPNESS across the entire frame. It's this attribute that I search for, and until now, never achieved. In my prior attempts, I listened to the advice from the "pundits", picking up a copy of the venerable Fuji 14mm F2.8, the Zeiss Touitt 12mm F2.8, Fuji 23 and 35mm F2.0, even the very similar 7Artisans 27mm F2.8, and none of them come even close to the TTArtisan for edge sharpness in infrared. Incidentally, I'm using a Kolari 720nm clip-in filter. Sure the TT has its issues -- vignetting at 2.8, tendency to flare with sunlight nearby, but all in all, this lens is glued to my X-T5 for now. This image was taken hand-held with this lens -- completely unedited!
