XF 18-135 stiff zoom ring...lens play on mount
Bessario
Hi!
So, as I see the zoom ring on 18-135 is quite stiff, probably because weather sealing and when zoom it seems that
friction between zoom ring is bigger than between lens and lens mount and that causing a little rotational play between the lens and mount for about 0.5 to 1 mm max. (as on my Nikon lens with even much bigger play) just what is tolerance between locking pin and pinhole on the lens mount. The manual focus ring is less stiff in so it does not causing moving the lens, as I suppose on some non weather resistant lens with light turning zoom.
What situation is by your sample, and what else could I do, because it seems to me that the stiffness of zoom ring is just average for that model, as the pinhole tolerance (without tolerance some pins would never fall in the hole).
Am I maybe wrong?
    • I do not use Flickr, so I do not know what their BB code is. All I did was copy the second link you provided, (starting at https: and ending at  _k.jpg — leave off the [img] and [/img] tags) and pasted it into the message. After a moment, a message popped up asking if I wanted to paste it as the image or as a plain link. I did this twice, the first time I had it paste in as the image and the second time as a link. Nothing fancy or tricky.
    • So do I just copy the BB code from flickr and paste it anywhere on the page like other forums or is there some other trick I need to perform to get it to post?
    • All software is the latest between camera and app. All settings are correct on camera. I have both lossless and uncompressed RAW files on the card in the camera. I have been up and down every reddit thread to no avail and am losing my mind… I’m doing all of the right things. It even sees my camera. It just doesn’t create the “drive” for it (see attached image screenshot).  Please Help!
