Is X-T100 worth to buy as on Nov 2019?
eric2410
Is having a viewfinder worth the upgrade cost? That's the main difference between an X-A5 and an X-T100.
The X-T100 came out 4 months after the X-A5. The X-A7 has been out for 2 months now, so it's possible that the X-T100 follow-on will be coming out in a couple of months. Of course, it's also quite possible that it's not.
