Does a slow card give me cropped files?
Hemanth
I used a slow card while shooting, I thought 16:9 was to blame..but all my files seemed cropped and looked different than what I’d shot. I remember shooting and turning off camera right after, does turning off the camera too quickly do this?..photos were cropped top way, some side ways..just looked ugly
