Back disp screen mode problem
Raphael8888
Hi all. I got problem with my back disp screen mode. it used to work before but now is blank. Can anyone tell me how to turn it back on.
ps. i think that happened after firmware update few days ago
Thank you
Edited by Raphael8888
I think I have the same / similar problem. After firmware update I don't get any image on my screen or the EVF.
The camera seems to be working fine, except it won't display and image from the lens. It's like I have the lens cap on, even if it is off.
Can you see anything on your EVF? Can you tanke pictures?
can take images everything is fine apart of that one mode with thumbnail which was showing live view before-now just shows taken photo
Thank you
This is normal this display mode does not show the picture where you have circled red. It only shows the af point
 Watch this from > 27:34
Fuji xt3 display guide > http://fujifilm-dsc.com/en/manual/x-t3/about_this_camera/display/index.html#change_indicators
