XT2 firmware upgrade
Perceptivelight
Hello I recently tried a new 80mm Macro lens on my XT2
When turned on the camera told me I had to upgrade the firmware,
So I returned home to do the upgrade which I later completed closely following the the instructions on your website. A fully charged battery and a newly formatted SD Card. The firmware updates for the camera and my 6 lenses were duely downloded. The upgrade proceeded with no lens mounted and without incident, the completion message was seen on the LCD. The camera was turned off.
Then in turn I continued to try and update each of the lenses again as per Fuji website  instructions BUT when the camera was turned on with the DISP button depressed the only selection to update was the camera body, NO menu selection item for any lens.
To make matters worse the camera will no longer opperate. when switched on the LCD flashes repetedly and eventually 'LENS ERROR' appears.  I repeated the firmware update procedure to no avail This would appear to be a firmware fault or omission has any one else had any similar issues?
    • I do not use Flickr, so I do not know what their BB code is. All I did was copy the second link you provided, (starting at https: and ending at  _k.jpg — leave off the [img] and [/img] tags) and pasted it into the message. After a moment, a message popped up asking if I wanted to paste it as the image or as a plain link. I did this twice, the first time I had it paste in as the image and the second time as a link. Nothing fancy or tricky.
    • So do I just copy the BB code from flickr and paste it anywhere on the page like other forums or is there some other trick I need to perform to get it to post?
    • All software is the latest between camera and app. All settings are correct on camera. I have both lossless and uncompressed RAW files on the card in the camera. I have been up and down every reddit thread to no avail and am losing my mind… I’m doing all of the right things. It even sees my camera. It just doesn’t create the “drive” for it (see attached image screenshot).  Please Help!
