By Ned_Sayer
I Just got a Fuji X-T3 from Amazon Warehouse deals, and the button feels off...
I used a X-T1 and have a X-t2 and they both feel very different to the X-T3.
I made a video to ask if this is how the X-T3 works or if I got a "faulty" unit.
By itchy shutter finger
1. IS Shortcut
2. Focal Length in Information Display
3. Y Axis Level Indicator
4. Multiple Exposures >2
For my purposes, the FujiFilm X-E3 is the most near perfect system on the market. Note that I said "near perfect". I very carefully made my body selection based on feature set and minimalism. The optimal ergonomics was icing on the cake. No other Fujifilm camera body could make me as happy as the X-E3.
That doesn't mean I don't think it could be just a little better, and rather than feeling the need of a different camera, I am hopeful for a modestly improved firmware as noted below.
1. IS Shortcut - There is no option to create a shortcut to turn off Image Stabilization via Fn, T-Fn, Q Menu, or MyMenu. XC lenses have no external switch to turn off IS (such as the XF lenses do), so the user must dive into the menu for this. Users who frequently go on and off the tripod currently must make that menu dive each time. As such a user, I would be very grateful for the ability to make such a shortcut.
2. Focal Length in Information Display - This would be helpful to zoom lens users. This information is available in exif, so I assume it can be polled for display.
3. Y Axis Level Indicator - Could be useful for scientific, engineering, or documentary purposes. I've grown so fond of the X Axis indicator, I can't imagine ever being without it again.
4. Multiple Exposures >2 - Fujifilm have done such an amazing job of maintaining the classic features we enjoyed back in the day. As I recall, however, every camera on which I could perform multiple exposures could perform multiple-multiple-exposures. I'd have no problem holding the photographer responsible for the exposure, but a photo with five or six exposures (without software sorcery) is still something I'd like to do on the X-E3.
And that's it. These four features gets the X-E3 as close to perfection as I can imagine on it's current hardware base. And I can make a better case for keeping the X-E3 an X-E3 than evolving to an X-E4 (hint: any further hardware feature or feature that appears on other bodies are not "minimalist", which is something that holds high value for me.)
Thanks for any consideration, and I'm pulling for you, Fujifilm.
By eric2410
Hi,
I am thinking to grab a X-E3 by this year Christmas but is it worth to buy new E3 or wait for the successor?
Some rumours saying that E3 will not receive an update but I like its weight and size as it matching to they style I shoot (I am mainly on street photography).
new X-Pro 2 & 3 is way out of my budget, so it is tough for me to consider the two.
Please feel free to share your ideas.
Thank you.
By DS122
Hi!
Fuji X-E3 for me is like my guitar processor - rule in few presets and then use them when needed.
This is great concept. There are a lot of great preset recommendations around.
I like very much photos from Tony Levin, famous bass player (David Bowie, King Crimson, etc).
Like this one:
More here.
Can you help me with camera quick settings that can bring similar result? Something like "Tony Levin Settings"
I am shooting jpeg only and do not use post processing or any other adjustments.
This is indeed an issue that occurs more frequently with X-mount and esp. combined with the larger/heavier lenses. We've had it several times on various X-Ts and only the X-H1 is really better (and the GFX). Make sure that when they tighten the screws they put a drop of Loctite on the tip of the screw. That really helps.
Sports Finder crops the display by 1.25x, "reducing the picture by an amount equivalent to increasing lens focal length by 1.25x" ... says the user manual. I assume this means the 23mm lens effectively becomes 34.5mm (in full frame 35mm format). The Digital Tele-Converter on the other hand gives an equivalent to either 50mm or 70mm. Is Sports Finder therefore just another digital tele-converter, or is it doing something else entirely?
By InResponse · Posted
I now know the reason for the "shake" the mounting plate on the back of the camera is a little loose. I will return it to the shop and give them the option to tighten the screws as I don't have the apropriate tools. -
By Klaus Armitter · Posted
Purchase I ordered my lens from the Pergear because it has discount when I bought it. And I use it most the time with my X-T4. AF The aperture can be adjusted by turning the aperture knob at the bottom of the lens to A. You can use your favorite aperture adjustment method according to your preference. Build quality Build quality is really good. The lens hood is made from metal. It's small and lightweight. Love my new lens. https://pergear.co.jp/products/viltrox-56mm-f1-4-stm-大口径-単焦点レンズ-fujifilm-xマウント-オートフォーカス-ポートレートレンズ
