Sign in to follow this
sean73
ISO 12,800 with 23 F2 - Festival Portraits
Thought you all may be interested in seeing some super low light photos. I was using the 23 F2 but wish I had the 1.4 in this situation. (I used the 16mm 1.4 on the wide shots of the stages). I still think the camera managed the noise well. ...noise reduction in PS.
Low Light Festival Portraits
Majority of the photos were shot at 6400 and above. 1/3 of them were at 12800  - all handheld with no flash
Obviously  they wouldn’t be good for printing but I think good enough for the web.
note: if you want to pixel peep first select the photo so it goes into the light box slideshow. Photos were exported from LR at 2000px long edge (not full resolution).
Note note: some of you may know how to describe this better than me but an F2 on a crop sensor is equivalent to approx 3.2 on a full frame camera  .. as well as lenses you also have to do the crop calculation on the F-stop  is that correct?
Edited by sean73
Share this post
Some folks will tell you 'no'. Put a "full frame lens" on an apc-sensor based camera and use the aperture ring to stop it to oh, say f-4. It is f-4 regardless of the sensor size. The part of the image that hits the sensor is coming from the center of the lens which is where the lens-equivalent conversion factor part comes into consideration.
Share this post
Loading...
    • By ibraxwane
      Hi guys,
      Hope you're all well.
      My Fuji randomly stopped turning on a few weeks ago. The screen turns on but not completely (as seen on the attachments). Changing to the Viewfinder also doesn't work, shutter doesn't go off...nothing works. When I turn it off, the screen stays on; I have to remove the battery for my camera to shut down. I've interchanged between my 3 batteries multiple times, and the problem persists.
      I've looked for solutions on forums, but never found anything that fits. Tried updating the firmware through an SD card but the camera won't even turn on for the update to begin in the first place.
      Any tips? I'd love to hear from you guys!
      Cheers,
      Ibra
      Hello guest! Please register or sign in to view the hidden content.
    • By Filand
      Hello,
      I have a quick question regarding the XT-2.  I jumped from a Canon 40D to the XT-2 some time ago.  I love the camera and the feel and output are fantastic for me.  With that said, I have noticed that I have a harder time (on the Fuji) transferring what I see in my viewfinder to my computer screen.  In other words there seems to be a disconnect between what I see in the computer and what I remember being in the viewfinder.  I don't think it is a color or exposure issue, maybe a framing?  Not quite sure.  Do I simply need more experience with the camera?  I'm using a 18-55 for both cameras.  Thank you.
    • By Marshall Timkii Hoang
      hi guy, I'm using X-h1, X-t1 with few lenses. I wonder should I buy an X100T or an extra 23mm f/2.0 lens. I'm gonna do street photography and sometime travel?
      Thank you guys.
    • By Thubten
      I have used cameras for a long time, none of them weather sealed, without any damage from water or dust.In fact I don't recall it even being an issue.But now I am deciding between an xt2 and xt20 ,mainly on this basis and the $700 price difference.I will never be out in the rain with this gear, but it will be exposed to ordinary dust, and perhaps high tropical humidity.I am leaning towards the xt20.This has perhaps been covered before, but I can't find a search function.
