Battery Terminals Exposed
The current Fuji NP-W126S batteries do not come with little caps or cases to protect the terminals. Has anyone found a decent alternative or do we all just sorta toss them into the bag and go with it?
The terminals appear recessed so I’m not overly worried but having come from other systems it seems... idk, odd.
Edited by MailerDaemon
Spelling
I use the case for a UV filter from Ritz. 2 Fuji batteries fit perfectly side by side.
Companies like Think Tank and Neewer make battery holders too.
Even if you don't, as long as you don't keep any conductive material near the terminals, having it in a bag or pocket should be fine.
Oo... thanks for the tip! I’ll take a look at both those products. I usually keep them in a single side of my camera bag so no other metal objects are around them. But for some occasions having a cover or pouch like the above would be nice.
Thanks, again!
 Share
    • I setup my C1 for bird and action settings. ISO3 (shutter 2000, 125-6400ISO, AF zone, bird). If I'm on a single ISO setting and select C1 it will not go to the AUTO3 setting. If I'm currently on auto iso1 or iso2 it will go to iso3 but the top iso value displays as 1600 even though I set it to 6400 max)? I basically still need to go in and manually change to auto3 to get it to work. Any thoughts would be appreciated.
    • LCD Problem on my X-H2. Camera is 3 months old.  Just this week, LCD was not going on, or it was on then went off, while opening it and turning it outward. Eventually it would come back on after a minute or two. Doesn't happen all the time, but did happen a few times while hiking in cool weather. Has anyone else experienced this yet? I have the settings so that the LCD goes off when I'm using the EVF and I know where that sensor is, so its not user error. I know there have been issues with Fujifilm LCDs in the past, so I'm concerned that this will get worse and I'll have to give it up for a month while its repaired. I'm still within the Amazon return window so considering sending it back for a replacement. All comments and suggestions are welcome and thanks!
    • There are several ways to fix that. Try this, go to System Preferences, click Security & Privacy, then select the Privacy tab. Scroll down and click Full Disk Access. There should be a little + symbol somewhere, click on it and you should be given a dialog box to find the app you want to add. Select it. Now, along the way you will have to enter your password (assuming you have permission to add / delete applications, etc.) to give permission for these thing to happen. An easier way is to delete the app, empty the trash, restart the machine, and reinstall the application, only this time give it the needed permissions as you are going. As far as the tiff files go, it depends on the converter you are using. If they export in 16 bit tiff format, (do not use eight bit) you should have the data but when you open it in your editor, it will have the selected profiles applied as a starting point. ie your white balance, film simulation, etc. etc. because that information is embedded in the tiff from the raf, and used by the editor as a starting point to display the image. Some manufacturers' raw files are actually tiff files with a little proprietary info added in, I have read that Adobe's DNG format is just that as well, a tiff file with a few other things tossed in for good measure. Fujjifilm is now using tiff as a storage option along with .jpg and .raf in their latest camera releases. It is a good format.
    • Hi Jerry, thanks so much; I already downloaded Rawtherapee v5.8. But as I am using Mac OS 12.6, probably there is some issue. There is an instruction in their website  '  Drag sh into the “Full Disk Access” pane under the “Privacy” tab in the “Security & Privacy” control panel in “Apple menu” > “System Preferences”. I tried to do but couldn't do it. So I didnt have the access to the photo folder. I already had other raw converter. Are all the data in TIFF kept as same as RAF? then I can edit it in darktable or Lightroom ( I have older version in my different laptop).
