Gaz55
X-T1 screen protector
Hi
i am sure this has come up before but any recommendations  for a screen protector for the X-T1
Just got my camera though the post today WoW
Share this post
GGS Larmor, nice and thick, scratch resistant and does well under the rain.
Very good visibility too and not too reflective under the sun.
I have the same brand for my Nikon 1 AW1 and it has survived several dive trips in the ocean and a fall about 5 feet straight onto the screen.
Share this post
I have a polycarbonate  ACMAXX 3.0" HARD LCD Screen ARMOR PROTECTOR.
​Not cheap, but cheap, in this case, can turn out to be expensive. Beware! Not all 3” do fit the X-T1 you need one specifically made for this camera or you might end up with a screen protector which also covers part of your image!
Share this post
I have the GCS Larmor one as well. Be aware, that since it is glass, it can be broken by applying pressure to it. Mine suddenly had a small section smashed I believe by the buckle on my camera strap getting pressed into it. I initially thought I had damaged the screen but it was just the protector.
Mike
Share this post
I'm using screen protectors from protectionfilms24.com for years, for cameras and other gadgets with screens.  Cheap, clear, and effective against occasional scratches, leave no residues when removed. I don't ask more.
Share this post
Thanks for all the help I am going to try Vidalog reply had glass before and found corners lift then it gets broken
So will give them a  try and i have not had them before
Thanks again all
Gaz
Share this post
I have them too on my XT1's. Worth their price (€25,00 ish).
Share this post
Loading...
    • By Marshall Timkii Hoang
      hi guy, I'm using X-h1, X-t1 with few lenses. I wonder should I buy an X100T or an extra 23mm f/2.0 lens. I'm gonna do street photography and sometime travel?
      Thank you guys.
    • By silverhow
      I have an XT1 and absolutely love it. I'm thinking of trading it in for an XT3 - but am wondering if it is worth it. I'm not really interested in movies, and most of the extra you get with the XT3 seems to be in the video area. Also, is the XT3 heavier than the XT1? I really like the light weight of the XT1.
    • By traveltarte
      Recently my XT1 stopped working, when I have a lens attached the lcd screen flashes for 20 seconds and then I get the message "Lens Control Error" on screen and am unable to take any shots. I've tried a few things already (listed at the bottom) and none of these steps have resolved the issue. I've tested it with my 16mm lens and another lens and the error seems to occur with any lens, so I'm sure it's an issue with the body and not the lens. When I remove the lens the error doesn't occur.
      I'm currently travelling in Colombia and according to their designated service centre here (who I'm not entirely sure I trust) I need to have the camera's main board ("tarjeta principal") replaced, for which they're quoting around $150. I just want to be sure that this really is the issue before I shell out the cash to have it fixed.
      Has anyone had this error fixed by Fuji and if so, do you know what element needed to be fixed?
      Thanks in advance.
      S
      Steps I've already tried:
      Turned the camera on and off; removed the battery for a few mins and replaced; updated the firmware for both the camera and lens; reset the camera to factory default settings; taken the lens on and off; cleaned the copper contact points both on the lens and the body.
    • By amirhoseinabedian
      Hello Guys
      My name is Amir, I'm a Photographer from Iran.
      I recently Joined this Community because I need your advice or opinion on a situation here.
      I'm a film shooter and recently I decided to buy a Fujifilm X Camera. I mainly do Landscapes, along with some portraits and street.
      I'm on a tight budget (roughly 1100$) and new Fuji products are very expensive here! (more than their normal price worldwide!) so I'm not in a good financial position to buy a Fuji X-T2...
      But recently I came across two options here. one is a brand new Fujifilm X-T1+18-55 kit lens around 800$ price tag (special offer) and the other one is a used X-T20+18-55 kit lens (roughly 2000 shots) around 950$.
      Depending on my needs, which one do you suggest? I'm planning to go with it for a minimum of 3 years so its a crucial choice for me here and also the weather sealing is a real deal breaker for me.
      what do you suggest? what should I do?
    • By joust1154
      Hi, so I shoot mostly using the LCD, from the hip, and I encountered a program today with my XT1's. Somewhat similar to an old post: https://www.fuji-x-forum.com/topic/1948-x-t1-lcd-fails-when-articulated/
      But my situation is a little different. When my LCD is completely flush, in the normal position against the body, it will be totally blacked out/looking like it's off. I've cycled the 'viewmode' and nothing has helped. I did a factory reset and updated the firmware. But I believe I have a body-to-LCD ribbon short.
      If I pull the LCD away it will work, but only in a limited range. From angled slightly upwards to completely flat facing upwards to the sky. If it's totally parallel with the body to facing downs toward the ground, the LCD will black out/turn off. I can still take photos when it's like this though.
      I'm pretty sure it's a short in the ribbon — if I push the ribbon around very gently, the screen will go on and off. But anyway, I would like to put this problem out there and see if anyone has encountered it before. The camera has seen a lot of use in the last 3 years, but no drops/damage. Luckily the EVF works normally and used XT1s are pretty cheap now.
      Let me know if you have any suggestions, thanks!
