I know most of you think the EVF doesn't lag in low light. And for the most part I agree, the EVFD gets more noisy but the refresh rate still high.
But I shoot with a flash in low light, so I turn my exposure preview off. So try this on your XT1s and see if you get the same lag I get, set the lens to f8, go somewhere relatively low light, and then half press the shutter... Can you see the lag?
The only way for me to get rid of the lag is just to mash the shutter and not do the half press. I don't like shooting like this because it feels like I get a slight shutter lag, compared to half pressing the shutter and waiting for the right moment (I use AFC with AF button set to AF and the shutter release set to exposure metering).
This happens because when you half press you will also get a DOF preview of your image.
When you half press, the aperture blades will close down to your chosen aperture (compared to being wide open when not half pressing).
There's hardly any light hitting the sensor so the EVF cant maintain its refresh rate
Wow. I saw this kind of lag on e2, and sometimes on x-t10 while testing.
Is it possible to turn off dof preview? On my sony a77 there is no this kind of lag.
I really have to question why anybody would be trying to shoot at f/8 in 'low light'. Maybe my definition of 'low light' is different to yours, but for me, 'low light' means ISO 3200-6400, f/2 (or faster) and 1/125th is still underexposing by more than a stop.
Yes, the aperture stopping down to f/8 will reduce the light coming into the camera dramatically and induce some EVF lag, but if you're in that dark a space with that small an aperture, I wonder what on earth it is you're trying to photograph.
I guess he wants greater DOF. That's quite often situation for events shooting.
Well duh. But f/8 is a helluva thing indoors. I do events in minimal light—the settings I listed before are very common for me to use and I still end up pushing the files half a stop or so in post—and if I'm looking to get a whole room reasonably in focus, we're probably talking about f/3.2-4 on a 28mm lens or wider. In fact I'm often left cursing how large the depth of field is, even at f/2.8, on some of the wider lenses to get a whole room in shot. There's a reason why the 14mm never needs to be stopped down.
I'm not saying it's wrong/impossible/whatever, I'm just trying to get my head around the concept of a 'low light' situation which calls for such an aperture.
Your settings are really common for indoor ambient light. Adding a flash will make it possible to shoot @ f/8. With 56mm that's quite reasonable aperture to get all in focus. I like ambient light more too but that doesn't mean one won't like to shoot with flash and large DOF.
Loading...
    • By AllanY
      I am struggling with underexposed videos using my X-T3 and 10-24mm with interior Real Estate videos even with a decent amount of natural and ambient light. The footage is just too dark unless I pump up the ISO to 4000 where it gets really noisy.
      What are the best wide-angle lenses for the X-T3 with regards to interior Real Estate videography where it's usually low light? Also, is there a budget friendly option? I've gone through the Complete Overview of X Mount Lenses but I was hoping for some recommendations specific to the industry and video.
      Thanks for any help guys!
      Settings:
      4K 29.97P I would prefer 59.94P to slow down some shots YouTube encoding prefers 30P ss60 F4.0 ISO 800-4000 200Mbps H.264 / H.265 Long GOP / ALL-Intra Eterna Custom White Balance DR400 Film Simulation Recording / F-Log Recording
    • By sean73
      Thought you all may be interested in seeing some super low light photos. I was using the 23 F2 but wish I had the 1.4 in this situation. (I used the 16mm 1.4 on the wide shots of the stages). I still think the camera managed the noise well. ...noise reduction in PS.
      Low Light Festival Portraits
      Majority of the photos were shot at 6400 and above. 1/3 of them were at 12800  - all handheld with no flash
      Obviously  they wouldn’t be good for printing but I think good enough for the web.
      note: if you want to pixel peep first select the photo so it goes into the light box slideshow. Photos were exported from LR at 2000px long edge (not full resolution).
      Note note: some of you may know how to describe this better than me but an F2 on a crop sensor is equivalent to approx 3.2 on a full frame camera  .. as well as lenses you also have to do the crop calculation on the F-stop  is that correct?
    • By dubiouswatermelon
      I recently got an XT20 with the 18-55 kit lens. Today I was trying it out at home, when I found out that when I try to zoom quickly in or out in manual mode, I see a horizontal light appear for a fraction of a second on the EVF. I cannot see this happening on the LCD. This happens only in manual mode, and not auto. This does not happen when recording a video. I am using mechanical shutter. But I don't think this is a shutter issue as I see this white line for a second when zooming quickly. Also I don't see it when I see EVF auto brightness from Auto to manual. The firmware is updated. Also tried zooming outside, I don't see that issue.
      The issue is as described here by another user:
    • By Arjun Sureshlal
      I use an X-H1.
      Right now there are 4 modes when you press the VIEW MODE button.
      The one I use is EVF + EYE Sensor. It feels right coming from a DSLR and it helps save battery. You can preview photos on the display with the playback button and everything's okay.
      But as soon as you want to go to the Main Settings you have to either switch the mode to any other mode (except EVF only) or change the settings using the EVF. Then to go back to EVF + EYE Sensor you have to press the view mode button 4 times. And If you want to go to “live view” that is LCD view, you again have to do the same process.
      It’s annoying. Is there any way to only put 2 options on the View mode button? Just EVF + Eye Sensor and Eye Sensor only?
      Or is there anyway to request a firmware update to
      • Show playback and settings on LCD while in EVF + Eye sensor mode.
      • A one press switch to EYE Sensor and EVF + Eye Sensor mode.
    • By wvoviivovw
      Hello. While using my X-T3 I encountered artifacts in video mode. With a white balance of 2500 and a transition to the blue spectrum, purple spots appear.
      Additional settings: 4k or FullHD, eterna picture prof, S tone -2, iso 640,  diaphragm 2.8-22, DR 400, shutter speed 1\40 - 1\200. Software 3.00
      This is evident on dark objects or on a yellow-green color. In the video, this effect is not visible. With atomos ninja 5 this effect is present. I also filmed this on video. Who faced such a problem? What could it be?
      Video artifact   (atomos ninja 5) :
      Thank you in advance.
