Fujifilm X-T3 Firmware 3.00 Released
Fujifilm X-T3 Firmware 3.00 Fujifilm X-T3 firmware version 3.00 has just been released. You can download it here. Strengthened the accuracy of face / eye detection AF performance The AF algorithm has been improved along with the accuracy of face…
The post Fujifilm X-T3 Firmware 3.00 Released appeared first on Fuji Rumors.
Full Article on Fuji Rumors
