Sirio
Switch slot button in Rec mode ** Firmware request**
In Playback mode is easy switch the slot of the SD card, just press and hold the "play鈻讹笍" button.
But in recording mode, you have to go inside menu and look for the right setting (boring馃槚).
Why not keep the same short-cut? Even in rec mode press and hold the "play鈻讹笍" button in order to switch SD card slot?
Thank you
Share this post
聽 Pasted as rich text. 聽聽Paste as plain text instead
聽 Only 75 emoji are allowed.
聽 Your link has been automatically embedded. 聽聽Display as a link instead
聽 Your previous content has been restored. 聽聽Clear editor
聽 You cannot paste images directly. Upload or insert images from URL.
Loading...
    • By rollsman4
      I checked the entire menu and can't seem to locate the firmware. 聽Any help is appreciated. 聽Thank you
    • By LePew
      Where are the heralded 3.20 firmware for X-T3?
    • By itchy shutter finger
      1. 聽 IS Shortcut
      2. 聽 Focal Length in Information Display
      3. 聽 Y Axis Level Indicator
      4. 聽 Multiple Exposures >2
      For my purposes, the FujiFilm X-E3 is the most near perfect system on the market. Note that I said "near perfect". I very carefully made my body selection based on feature set and minimalism. The optimal ergonomics was icing on the cake. No other Fujifilm camera body could make me as happy as the X-E3.
      That doesn't mean I don't think it could be just a little better, and rather than feeling the need of a different聽camera, I am hopeful for a modestly improved firmware as noted below.
      1. 聽 IS Shortcut - There is no option to create a shortcut to turn off Image Stabilization via Fn, T-Fn, Q Menu, or MyMenu. XC lenses have no external switch to turn off IS (such as the XF lenses do), so the user must dive into the menu for this. Users who frequently go on and off the tripod currently must make that menu dive each time. As such a user, I聽would be very grateful for the ability to make such a shortcut.
      2. 聽 Focal Length in Information Display - This would be helpful to zoom lens users. This information is available in exif, so I assume it can be polled for display.
      3. 聽 Y Axis Level Indicator - Could be useful for scientific, engineering, or documentary purposes. I've grown so fond of the X Axis indicator, I can't imagine ever being without it again.
      4. 聽 Multiple Exposures >2 - Fujifilm have done such an amazing job of maintaining the classic features we enjoyed back in the day. As I recall, however, every camera on which I could perform multiple exposures could perform multiple-multiple-exposures. I'd have no problem holding the photographer responsible for the exposure, but a photo with five or six exposures (without software sorcery) is still something I'd like to do on the X-E3.
      And that's it. These four features gets the X-E3 as close to perfection as I can imagine on it's current hardware base. And I can make a better case for keeping the X-E3 an X-E3 than evolving to an X-E4 (hint: any further hardware feature or feature that appears on other bodies are not "minimalist", which is something that holds high value for me.)
      Thanks for any consideration, and I'm pulling for you, Fujifilm. 聽 聽
    • By JamesKL
      I bought my X-Pro2 in June, 2016, and I have never updated the firmware. I want to get to the latest firmware. Is the latest version (v5.00, I believe) comprehensive, and upgrade directly to that version,聽or do I need to load each past firmware version in order and individually? 聽Thanks for any help you can offer!
      James
    • By vuki
      friends, I just read on the fuji site that 4.01 is a roll back to 3.0 and now I cant shoot f-log in camera. I shoot drone in two days and I promised 4k f log to the director and dp. I don't have time to source an external 4k recorder. I could use a .dat of the 4.0 but cant find it anywhere. can someone post a copy. I just chatted with a xt2 4.0 f-log shooter on instagram and he's not having any problems - running 4.0 is a risk im willing to take. let me know if you have and can post a copy.聽
      x love
      Hello guest! Please register or sign in to view the hidden content. /uploads/emoticons/default_smile.png">聽
