Sign in to follow this
ragnor
X-E3 vs. X-T30
Hi all,
A little bit of background: I have a Canon 550D. I have a couple of lenses, but I basically always use the 35mm f2 since I got it, due to it´s size and versatility. I use it 95% for travelling and street photography. Basically photo, although I also like to take videos eventually (I mostly take them with a GoPro now).
Aesthetically, I like the small X-E3.
So, the question is: is still the X-E3 worthy, or would the new X-T30 be a better option?
In case of going for an X-E3: I´ve just seen a great deal (800€ for a new one with 23mm f2). Is it the price expected to go lower in March, once the X-T30 is on the market? Did that happen before on other launches, or the prices aren´t that much affected as they are for two different segments (although they are quite similar cameras)?
What are your thoughts?
Can you help me deciding?
Thank you!!
Share this post
The X-T30 is going to be faster. Better AF-C (AI Servo in Canon-speak), higher FPS, better video.
For stills performance things are largely going to be similar in single-shot mode, you should see faster AF lockon and more usable face tracking on the X-T30, but other than than it's probably a wash. It's in video and continuous AF/Drive where the big changes between the 3rd & 4th gen bodies (X-E3 is 3rd gen, X-T30 is 4th gen)
That said, right now it's VERY hard to beat the launch packages on the X-T30 with the f2 primes (23, 35 and 50 all are offered). That's going to be the best price/performance right now. You might look for the 35/2 package if that's what you are used to shooting with your Canon. DO be aware that 35/2 on Fuji is a tad wider than 35/2 on Canon, because Canon has a higher crop factor (1.6x vs 1.5x for Fuji).
The X-E3 will likely slowly decrease in price until the X-E4 arrives (which will almost assuredly be the same featureset as the X-T30 in the X-E body).
It's also worth noting that despite the looks, both bodies are very close in size. The X-T30 adds the viewfinder hump, pop-up flash and a flip-out screen for a pretty small size change.
Share this post
Loading...
