OIS in Zoom lenses
sachafilms
 Share
It isn't easier. It's a marketing decision. A zoom is going to be heavier and slower than a prime in its range and harder to hold steady. The market for primes is much smaller than the market for zooms and they're more likely to be bought by people with a specific interest and, probably, better technique.
I know these are great facts because I made them up myself and I'm impressed. Actually the 18-55 is lighter than the 16 1.4, but I suspect the average buyer is much more likely to buy a zoom and is happy to pay for stabilization rather than learn camera holds and body bracing to steady a lens. A really quick look tells me the only primes with OIS are the 80 macro and the 200. The only zoom without is the exceptionally heavy 16-55. That an inexpensive and light lens like the 15-45 has OIS suggests to me that it's a marketing decision - even in a budget lens people will pay for the anti-shake.
It's probably a number of factors. Here are some possibilities:
  • people buy primes because they value maximum image quality, while people buy zooms because they value convenience
  • people who buy primes might be expected to be more experienced at holding a camera steady, and to own a tripod, than purchasers of zooms
  • people who buy primes might value a smaller lens
  • a number of the wide-angle primes were designed for use with the X-Pro1, and thus had to be kept rather small to minimize blocking of the optical viewfinder
  • many primes are available with large apertures if you want faster shutter speeds, while fast zooms are rare
Loading...
 Share
    • That's a really funny question, since it would have been easy to calculate it yourself based on the file sizes! 😜
    • Have you tried pulling out the main battery and leaving it sit on a shelf for several days to let the settings backup battery / capacitor completely discharge? This should cause the settings memory chip to lose all of its current settings and go back to the factory defaults — as of the last update.
    • Hi lolo,   have to say I can't believe that this has not had more attention as you have done an absolutely incredible job here! I was in the exact same situation of moving from LR to C1 and really loving it except for missing my film styles pack and finding the native options available for C1 not quite there in terms of accuracy and quality. I looked all over the place before finding this post and links. What a relief!  Many thanks for your efforts here mate, very much appreciated!  cheers, LB
    • Hi there. I've just bought a second-hand X70 and I can’t seem to reset it to factory settings. When I choose reset in the menu I can't toggle to the required options, they're in red, all the commands I put in only toggles between 'ok' and 'cancel', the manual doesn't offer any help either. I would be very grateful for some help! Many thanks in advance.
    • Dimsol, I will mention something that may be very obvious to some but this happen to me. The shutter speed was set on "A" while I was testing my X-T4 in dimm light. I was under the impression that my X-T4 was taking 2 picture, but is was just the shutter opening and closing at 1/4 sec timing. Is this the case or do you actually have 2 pictures saved on memory card per press ?
