Filipe Samora
Show clip duration on XT3
Hi there,
Is there any way to display the actual clip duration while recording video on the XT-3? The screen only shows me the remaining time on the card. I cannot see the clip duration either when trying to play back clips.
Any suggestions would be much appreciated.
Many thanks
Share this post
Assuming you don't need timecode for any other purposes such as syncing audio or multiple cameras, you can use this feature to show you the clip duration as you record.
To do this, go the Menu > MOVIE SETTING (screen 4/5) > Time Code Setting,
  • turn on TIME CODE DISPLAY,
  • reset START TIME SETTING to 00:00:00:00
  • set the COUNT UP SETTING to REC RUN
Hope this helps,
Edited by thewinterolympics
match uppercase value of the x-t3 menu
Share this post
I have been using that workaround in critical situations but it's not practical since, on any given day, I need to shoot 50+ separate clips, and having to reset the TC every time is a pain in the royal neck.
Sometimes you wonder what gives...such an amazing camera, the XT-3, without a basic feature you'll find in any nondescript toy camera capable of shooting video of sorts. Guess will just have to live with it, until someone at Fuji also believes it's a good idea to provide users with the actual clip duration while recording.
Happy filming!
Edited by Filipe Samora
Share this post
Loading...
