Bill5818
Remote Shutter release not working on XT2
I have three remote shutter cables, all with the 2.5 mm jack. These cables have worked flawlessly for the last several years with all my Fuji and Canon cameras. Just the other day, they stopped firing the shutter on my XT-2. A half press works as expected, but with the full press nothing happened. All three cables work flawlessly on my XT-10. I have blown out the socket on the camera, and it looks clean. Any ideas would be much appreciated.
Share this post
For what it's worth (not much, I'm afraid), I can confirm that my several Canon RS-60E3 remote releases (2.5mm jack) are still working fine with my X-T2 and other Fuji cameras. It does sound as if something's preventing a connection in your X-T2's 2.5mm socket. Sorry I can't be of more help.
Share this post
Sounds to me like you have something in the hole. Check closely to make sure. If not, it is not likely that all three releases are bad
I just checked my XT-2 and I have a few different brands  of 2.5 mm jack releases and they all work. The contact points in the hole are likely just flexed metal for the side and that can be flexed too much and lose contact. Try wiggling the plug when you engage the shutter button.
If all else fails consider getting a remote trigger that fits the USB (small part) or go truly retro and get a cable release. Either one of these work-arounds would likely be much cheaper than having the socket replaced. Good luck...…….Bob
Share this post
Same issue here with my xt2 that reacts abnormally to focus/shutter control . I suspect a short circuit between focus and shutter when the 2.5mm jack is engaged. Focus react when contact shuts buf stay engaged after contact release
Edited by alpheratz06
spelling
Share this post
Loading...
    • It all depends on what you want and need, a cheap option with TTL is the Nissin i-40 as mentioned above if you use manual flash (which I would recommend) Youngnuo is a very affordable option also offering remote triggers for off camera use.  I have the nissin i-40 whish is easy to use and offers TTL and a couple of Youngnuo Flashes with remote triggers.
    • Any street/public photos of Hong Kong (Open Thread)     Hello guest! Please register or sign in to view the hidden content.
    • I live in Yuen Long, Hong Kong.  Just bought X-E3, X-T30, 16mm 1.4/f, 18mm 2/f, and 35mm 1.4/f.  Here is the set of photos I used them to record Yuen Long, Hong Kong.  I only use the Film Simulation of Acros Red.  I will keep updating this album.  Cheers!
    • Hello guest! Please register or sign in to view the hidden content.
    • (From an older inquiry I responded to here) I bought the pair listed below. Both are made by Godox but are rebranded house brands from Adorama. B&H also has Godox rebranded house brands though I don’t know their name for it. The reason I went with Godox is they are inexpensive and rated very high on multiple websites.  I first bought the pair as Godox branded but the warranty was a joke. The flash and off camera support both had a card insert explainin
