IanF
Capture One Pro + GFX 50S tethering
Hi all,
I downloaded the new version of Capture One 11.3, which supports tether shooting on GFX cameras, but I'm having some trouble getting things to work properly.
When I connect up the GFX 50S to my MacBook Pro the software sees the camera and lets me trigger it remotely. But the RAW image that's transferred over only shows up as a VERY low res preview. The rest of the image is missing. The files have transferred, because I can see them on Finder and open them through Lightroom/Photoshop. Whatsmore, I can shoot Raw files to card and open them in Capture One 11.3 OK.
Anyone else had any problems?
Ian
Share this post
Yes, I'm also having problems, but they seem more fundamental than yours! I'm using the full version of Capture One Pro 11.3. The GFX 50S is not recognised at all when I try to tether it. It is connected to the computer (MacBook Pro) properly, as it shows up in Fujifilm X Acquire - which also means it's not the cable causing the problem. My PhaseOne connects normally, but C1 thinks the GFX 50S isn't there. I've tried all the different settings in the connection menu on the camera, and it makes no difference. The Fuji raw files are recognised when imported - it's just the tethering that isn't working.
Any thoughts/experiences would be very welcome.
Bruce
Share this post
Bruce -
Just off top of my head, try quitting Fuji Aquire. It might be hijacking the cameras connection to your MBP.
Strangely, after speaking with CO support, mine started working perfectly without me changing anything. Not sure why so I don’t have full confidence in the set up yet. But quality of Raw conversions in clearly superior to ACR.
Let me know how you get on?
Share this post
Loading...
    • By fleckintosh
      Hello!
      Here is a completely reworked, refined Set of ICC Profiles for Capture One, made for X-T1. It matches the In-Camera Filmsimulations much better than the original Set, which I posted last October here.
      Another Set, made for X-Pro2, Incl. ACROS ICC Profiles, is also included in this post. I renamed them to have an alternative Option for my X-T1. These ICC are slightly different, Blacks & Shadows & Colors are more decent.
      Enjoy!
      Dropbox-Download
      Hello guest! Please register or sign in to view the hidden content.
    • By 。。。DTB 。。。
      I created this slideshow of images that I took of a maiko walking around Miyagawacho, in Kyoto, this September. I edited all of the images in Capture One using Fujifilm's new film simulation, classic negative. When Fujifilm provides the X-T3 with classic negative via a future firmware update, I am sure it will be even better. However, I am liking the new film simulation already for street photos. What do you think of classic negative for your own photos?
      Fujifilm X-T3 , Canon EF 300mm f4L IS, Fringer EF-FX Pro ii
    • By Joao Marques
      So I m thinking on going for the Fuji GFX 50R, anyone has the experience on using the Sony A7R III and using the Fuji? tell me about your experience
      autofocus behaviour: eye autofocus, focus acquisition in dim light  image quality: colours, sharpness. Thanks
      João
    • Guest Him
      By Guest Him
      Anyone using this case, if so what are your thoughts on it?
    • By oxjox
      I just want to make sure I'm doing this correctly and getting everything I can out of this software. Having to purchase an extra plugin and opening different windows just to take a picture makes this feel like something's not right.  I did watch the instructional video but it sort of stops right at the point where you start using the software.  I guess aside from the tether program acting completely disconnected from Lightroom, I can't get focus to work.
      I'm on LR CC and have purchased the Fuji Tether Plugin Pro v 1.602.  My XT-2 is on FW 2.10. I open LR and start a new tethered session; File > Tethered Capture > Start new Tethered Capture.  I get a control window that pops up once it recognizes my camera and I can take pictures with the 'shutter' button.  These photos show up in my Library in LR.
      I can also go to my menu bar and select Show Fuji Tether Plugin Pro.  This brings up a window which, by default, is on Camera (USB) on the left and Preview on the right.  This view does absolutely nothing. I can select PC from the menu on the left which also at first does nothing until I select LIVE VIEW on the right.  Now I can see my camera and make some exposure adjustments.  So, when I want to view what my camera sees, I should not use the menu that says Camera and instead use PC.
      What It seems I can not do is use the AF/MF Settings.  Once I turn on Focus Area, I can click in my frame to designate a focus area but that doesn't actually tell my camera to focus.  When I click on my shutter button, nothing happens. I can not take a picture with the AF/MF Settings turned on.
      In the Preferences for Fuji Tethered Plugin Pro, there's an option to "Specify action of clicking on the Live View window". The options are Move Focus Area, Instant AF, and Instant AF and Shoot. The first one is the only one that results in a proper action.
      If I exit out of the Fuji Tethered Plugin Pro and just use the built in LR capture tool, my camera will focus as expected.
      Please let me know what things I'm getting wrong. All I want to do is see a large view of my subject, click to focus, and take a picture. I've spent too much time and money trying to make this work.
    • i'm 90% sure there will be an X-E4 the X-Pro3 and X-T4 have both been more focused towards professional use. i believe fuji should have a competitor for the sony a6000 line in the form of their X-E line. it will probably not get IBIS like the X-T4 but will get the same features as the new X100v just my opinion...and my hope...
    • They don't appear burned, but a but too shifted to the right. Perhaps is just a matter of taste. But as I say, most pictures, to just look 'normal', I have to compensate is by -1/3 or more typically -2/3.
    • Yes - provided you are using a version of the Adobe software which supports your camera. If you are using a subscription version of the Adobe software and keeping it updated then your camera should be supported.
    • Good morning friends! i have been browsing the internet but can’t seem to find a clear answer. Are Fujifilm camera profiles and film simulations now available for RAW files in Adobe Lightroom and Adobe Canera Raw please? I have been using this software for too many years to make a switch easily so I would be grateful for any feedback Thank you
