redfishingboat
XF2X TC teleconverter problem/question
Hello XFFs
I use a Fuji X-T2 and I've had the 50-140 2.8 for a couple years and love it.    I recently picked up a used copy of the XF2X TC teleconverter over an internet transaction.   It arrived today, I popped it on the body, mounted the 50-140 and when I turned it on, the LCD started flashing and the camera was clicking.
I was disappointed until I remembered that the 50-140 needed a firmware update to operatewith with the TC, so I downloaded and applied the update (1.00 -> 1.21)  to the 50-140 lens but the problem persists!  In my head I vaguely remember there might have been a need to apply the firmware updates in a certain order, but I'm not sure and web searches have not been helpful.
Did I get screwed on a dud TC by an internet scoundrel? Or am I just missing something obvious?
-Mick
Share this post
If it still does not work, the tc is probably defective
Confirmed this is the case -- on very close inspection, one of the connector pins is slack.    But the seller agreed to return/refund.  Whew!!    Thanks for replying!
Share this post
Glad I read this.  I have the 50-140 Zoom which I love, and have been looking for a pre-owned 1.4 TC but have found none for sale (although I've only been looking for a few weeks).  After reading this I think I'll bite the bullet and buy the TC new.  I assume that few that own the 1.4 TC part with it.  I've heard mixed reviews about the 2.0 TC with either the 100-400 or the 50-140 and the 1.4 TC seems to get unqualified great reviews from those that use it.
Share this post
I got rid of my 2x tc because it made the 100-400 far too soft at the long end. The 1.4x works really well with my 100-400 and also the 80mm macro.
Phil
Share this post
Loading...
    • After you have some practice at these, you might find it worthwhile to invest a couple of afternoons in a library learning about various  photography techniques— wait until after you have that practice in so that what the authors are saying will make more sense. For instance, dragging the shutter — a wonderful technique, will seem like it is the opposite of what I have had you do in this thread. But it is not, not really.
    • Capture One Express for Fuji is free and quite capable. I use the paid version personally, but the free version covers most needs if you don't batch process and don't mind not being able to make your own styles.
    • Only 2 lenses? 10-24 and 55-200 would be my choices. But I'm a landscape/nature shooter who hikes, as much as I love primes if limited to two lenses I'd have to go with those. For a second lens to pair with the 23/1.4, I'd pair the 56mm f1.2 for sure.
    • Brand new cameras tend to end up with a flurry of firmware updates for bug fixes, once it gets some time out there things will settle down although Fuji tends to release more firmware updates than other makers, adding capabilities and updating to improve older bodies performance with newer lens releases. The X-T4 is very new and still in the bug fix mode.  The X-H1 was actually much worse for that when new, but has been around long enough to mature.
    • Options two and three are really good ways to go. I never cared for option one for the reasons mawz mentions. Also, keep in mind that sunset, sunrise shots in general tend to look well with the contrast between color and dark.
