My X-T@ appears to have lost its ability to autofocus. Assuming that this is a mechanical problem, where can I send it, and is the work likely to be good? I should add that it has a cracked rear screen as well. (I fell but mostly protected the camera.)
My thumb is getting all wrinkly while I wait this problem out.
:huh:
I suppose you have left the cap lock on and instead of 2 your wrote @.
First of all have you checked that this inability to focus is with all lenses?In that case it might be the body. In case it is only on one lens then it is the lens and not the camera.
No Fuji lens or cameras, that I know, has mechanical autofocus ( like some NIKONs) but they all have focus by wire, the inability to autofocus might lay with the body or ( and who knows, perhaps AND) the lens.
The cracked rear screen is of course a body problem. Should you need to repair both you may want to find out beforehand how much the repair will be. Were you insured ( travel insurance?) when the screen cracked? You may be entitled to an insurance coverage.
I don’t think you have West Coast Options as the only repair centra I can find are both on the East Coast
http://www.fujifilmusa.com/support/ServiceSupportRepairContent.do?dbid=674543
https://camerarepair.fujifilmusa.com/Forms/RepairForm.htm
this is from Fuji site:
If you have any questions please contact FUJIFILM at 1-800-659-3854
